Scraping Brake Pad Noise....
Old May 3, 2006 | 06:32 PM
SMU09's Avatar
Default Scraping Brake Pad Noise....
Old May 3, 2006 | 06:43 PM
techbod's Avatar
Default RE: Scraping Brake Pad Noise....
in one "dust cover" touching rotor
Old May 3, 2006 | 07:02 PM
SMU09's Avatar
Old May 3, 2006 | 10:14 PM
AWDaholic's Avatar
Senior Administrator
We're semi retarded 'round tehse parts. Which atually means that we're as dumb as a Truck
Yes, that's what he's sayning. Sometimes you hafta kinda tryN figR out what we mean, from what we say. Sometimes not. This/that isn't a NOT time[&:]
Do you knwo if they lubed the slides when they put everything back together?
Are you SURE it's the brakes?
Old May 4, 2006 | 12:25 PM
north5995's Avatar
One of the pads may not be seated properly. Check all the dust covers though first.
Old May 4, 2006 | 01:07 PM
avanttripleloop's Avatar
they probably used semi metallic pads when organics are supposed to be used, your getting a little piece of metal that is acting like a record player needle on your rotor
Old May 4, 2006 | 01:43 PM
techbod's Avatar
my apolls I thought you would understand that's exactly what I meant but other things could be causing it like edges on the rotors "as the pads wares in they cut into the rotor leaving build up on the outer edges thus causing noises, next is the emergency break sticking on slightly then there is the pistons sticking/cheap break pads/dust covers "quite" a list so a good service to the breaks might be a wise thing
Old May 5, 2006 | 12:38 AM
SMU09's Avatar
SilverSurfer01
Jan 19, 2012 02:52 PM
mazc00
Audi Q5
May 4, 2011 12:38 PM
chris
Nov 6, 2008 12:26 PM
yohan
Jun 1, 2007 08:33 PM
sandman
Aug 31, 2005 08:19 PM
