Seafoam question
Seafoam is great. Full can in the gas tank and then fill up at least halfway. You can also treat the oil (put 1/2 can max into the oil, drive 100 miles, and then change the oil and filter - this will break down sludge and crap). You can pull a vacuum line and suck up about a coffee mug's worth as well, let it sit for 10-15 minutes, then fire it up and let it smoke out the neighborhood. That'll break down carbon deposits in the engine and help smooth things out.
For everything else, follow the manufacturer recommendations - mineral oil-based power steering fluid like Pentosin CHF11S, DOT 4 brake fluid, and whatever oil composition and viscosity is recommended for your car.
