spick n span brakes
Old Dec 19, 2006 | 07:30 AM
duburban's Avatar
Default spick n span brakes
I'm curious about cleaning of the caliper mounts. How should i clean these and other brake components to ensure i do an A+ job. I've been in there once recently and i want to make it my last time for a while. One of my pads isn't seated right so i'm going back in, while i'm there i want to properly clean the hangers. Sandblasting? Wire Brush? What do ya'll do with this? Vermont car...
Old Dec 19, 2006 | 12:49 PM
rayveedub's Avatar
Default RE: spick n span brakes
if there is no paint, a can of brakekleen.
Old Dec 21, 2006 | 12:03 AM
dankhound's Avatar
A wire brush or file should take most of the rust of the caliper bracket where the pads slide.
Old Dec 24, 2006 | 04:19 PM
ImTheDevil's Avatar
Agreed, use brake cleaner and/or Simple Green and a wire brush and it'll clean it up as well as can be done without sandblasting. Afterward, since you're in there, might as well paint them up too (black or silver to me looks the best - makes it noticeable but not too much so) - hit 'em with high temp paint and high temp clearcoat and it can help the brake dust not stick so much as well.
Old Dec 24, 2006 | 10:31 PM
tractioncontrol's Avatar
If they are not seating properly check to make sure the caliper pins move freely inside the rubber accordion boots, they can be pulled right out of the rubber boot if they need greased (I generally use bearing grease or antiseize to grease them) and make sure the boots are properly reinstalled on pin when finished.
holov
Mar 16, 2015 09:52 AM
ericcota2003
Apr 27, 2012 01:17 PM
bigsnowdog
Mar 13, 2008 02:18 PM
wildzx
Nov 9, 2007 12:42 PM
JDCrowe
Mar 19, 2005 12:31 AM
