Steering Sounds Help
Old Dec 19, 2008 | 02:16 PM
railrunner's Avatar
Default Steering Sounds Help
I have an 03', A6, 4.2 sport. I am hearing some clicking/popping sounds when turning left or right, particularly at slower speeds and in pulling into or leaving a parking space. Sound seems to be on the steering column under the dash. No whine or difficulty when turning.
Any thoughts?
Old Dec 22, 2008 | 12:37 PM
SAudi's Avatar
if this is the same sound im thinking of then its the inne tie rods going, i had a similar sound on my a4 that sounded like the front was about to fall off and finally i discovered that the inner tie rods were shot hopefully after replacing them today itll quiet everything down.
Old Dec 23, 2008 | 12:48 PM
matasci's Avatar
also your inner and outer cv boots if they are busted grease will be every where and you will hear it when you turn(outer) and when driving streight (inner) cv boots are on your drive axel's if you didnt already know
good luck
Old Dec 23, 2008 | 08:49 PM
SAudi's Avatar
oh yeah check the cv joints, but if its the same sound im thinking of which is more of a groaning popping noise, then its definetly the inner joints (just spent 500 to fix that ****), which BTW if you decide to do the inner joints i have a OEM set from audi if you want them for cheap.
Andog62
Oct 21, 2007 05:54 PM
deangelito
Jul 17, 2007 08:37 AM
sheepcan
Feb 20, 2007 06:44 PM
