Are these rims for an Audi...ans are they worth $100
I'm hoping these are gonna fit my 93 100S...I am not sure what kind/model car these came off of....I'm told it was some Audi model...does anone know? are these good rims...worth $100?
this is my car..will these be an upgrade
[IMG]local://upfiles/43989/2EF26764BF25421E9A09CBD569621B72.jpg[/IMG]
[IMG]local://upfiles/43989/3AFB49EEE01A4333BDCA9438F017F47E.jpg[/IMG]
[IMG]local://upfiles/43989/417B562E31484CB987ACE4F010ECCD9F.jpg[/IMG]
You need to find out from the seller (or if you have access to the wheels, look on the inside of the rim or the back of the spokes) to find out the specs for the wheel. You need to be concerned with bolt pattern and spacing (ie, 5x112) and offset (a number such as +35). Find out those specs, and then check www.tirerack.com. Go there, select "shop for wheels" and all the wheels for your car (after you enter your car's information) will come up. Click on any of them and check those specs for the new wheels. If they match up, they'll fit your car. You can shortcut this process too, by going to tirerack.com, call and talk to a service adviser, and give them the specs of the wheels you're talking about in this post, and they can tell you if they'll fit.
Those are Jaguar rims, they won't fit your Audi, but if they are straight and in good shape you could probably flip them on Ebay and make a hundred or so. Those are the "desireable" rims for the older XKS/XK6 cars, but they won't fit the newer (Ford) stuff.
morpheous
Aug 6, 2010 12:42 PM
