Tie rod ends , aftermarket or OEM!
Old Nov 12, 2008 | 01:37 PM
redhammer's Avatar
Default Tie rod ends , aftermarket or OEM!
I need new tie rod end on the drivers side on my allroad, not sure what to order, lemforder, meyle or some other brand. I think lemforder are factory but they also cost a lot more then meyle etc. Also would it be ok if I replace just one tie rod or should I do both, there is nothing wrong with the other one. I want to try and do this by myself.
Old Nov 12, 2008 | 01:56 PM
soundguy's Avatar
I replaced mine with Meyle. About 8 months after that, I replaced my entire control arm assembly with a Febi Kit.
The Meyle were far stronger and beefier than the stock.
The Febi Looked just as good as the Meyle.
I believe Febi has a better reputation than Meyle.
For the TRE's, I think both are better than OEM.
Old Nov 12, 2008 | 02:11 PM
redhammer's Avatar
I was reading a post where somebody said we should stick with oem, but it didn't provide any explanation why. Can I do just one or I should do both?
Old Nov 12, 2008 | 02:21 PM
soundguy's Avatar
Personally, I like the Febi or Meyle better than OEM.
I'm not a tech though.
Replace both for sure. After that, get an alignment.
You may want to go to a tire place and have them check your control arm assembly before you do the TRE's.
After I did my TRE's, I went to get an alignment, and they told me that the control arm bushing were shot and an alignment would do no good.
Of coarse I waited way too long to replace the control arm assembly and in the mean time, my front tires eroded to the bare radials.
My point is, I should have done the entire control arm assembly when I did the TRE's. Could have saved myself a bunch of money and time.
Old Nov 19, 2008 | 01:32 AM
spheromike's Avatar
SoCal Crew Member
I am having issues with my front suspension it is really squeaky is that a tie rod problem
Old Nov 19, 2008 | 10:46 AM
redhammer's Avatar
I ended up ordering lemforder,I am too getting some squeaking noises from the same area, we'll see if it's the tie rod.
Old Nov 19, 2008 | 11:19 AM
hcaudikeed's Avatar
squeaking is probably suspension related. im replacing my tre's now and i had rattling and vibration in the wheel and steering area of the car, and a lot of play in the steering. control arms and bushings were all fine.
Old Nov 22, 2008 | 01:59 PM
redhammer's Avatar
little update: I tried to remove the tie rod on two occasions, without success. First it wouldn't move from the inner tie rod , then it started to spin, I thought I got it loosed but then I realised the outer tie rod was spinning in the middle. Basicly, the threaded part wasn't moving but the other part was turning. I thought it was one solid piece.
norcal89451
Apr 8, 2013 09:15 AM
Quattro_1.8t
Jan 19, 2008 04:12 PM
oettinger1919
Jan 18, 2008 05:00 PM
trey
Oct 3, 2005 11:50 AM
BFlan2001
Sep 28, 2005 12:56 PM
