totally amazing!!!
Old Jul 13, 2005 | 09:53 PM
iano's Avatar
Default totally amazing!!!
you are obviously curious about what is so toally amazing. well let me explain. i explained the problems with my front suspension last saturday. to re cap- the front left suspension has gone up by half an inch. it has had some new parts, all were correct and fitted correctly. it has had two new shocks in the back. however no one can give me a logical diagnosis. today i decided to get out my tape measure and discovered that the front left is up by 15mm. not only that, but the wheel also appears to be 10mm more forward than the right hand side wheel using the moulding on the wing as the fixed point. i can't measure it but i am convinced that the wheel seems to be more cambered than the right side. it's fairly obvious to see when you know to look for it. what's amazing about that. well....nothing but i bet you would have overlooked this message if it was entitled "dull suspension problem". however it does shed new light on the problem and leads me to a more simple question- what can bend in the suspension that would lead to the wheel being so far out of line.( please forgive the lay man's terms)
Old Jul 14, 2005 | 12:12 PM
jukeit's Avatar
Default RE: totally amazing!!!
Sounds to me like your alignment is totally F'd. Check out this link that explains the finer points of alignment. I think the "set back" section will be of particular interest to you.
http://www.familycar.com/alignment.htm#Cas
Old Jul 14, 2005 | 10:24 PM
iano's Avatar
very informative. a great help thanks a lot.
Old Jul 20, 2005 | 01:52 PM
brrman's Avatar
you need to stop crossposting as well, iano
https://www.audiforums.com/m_102453/tm.htm
Old Jul 25, 2005 | 02:15 PM
iano's Avatar
fair enough. i'm absolutely desperate to solve this problem. it's not a budget thing. the world and his dog has had my car and it's still lop-sided and i'm still no closer to fixing it.........
larandbec
Aug 29, 2011 09:52 PM
coloradoA8
Feb 28, 2006 03:55 AM
iano
Jul 18, 2005 08:23 PM
iano
Jul 14, 2005 12:31 AM
