TT Instrument Cluster Problem
Old Sep 30, 2006 | 08:27 PM
raschul's Avatar
Default TT Instrument Cluster Problem
Please help. On cold mornings, upon start up, all gages flash on and off, needles jump back and forth. Date, time and trip odometer all reset. Stops after about two minutes. Any ideas?
Old Oct 7, 2006 | 12:57 PM
dankhound's Avatar
Default RE: TT Instrument Cluster Problem
Check the connections on the back of the cluster. They may be loose. Sounds like the cluster is either losing power or ground somewhere. IT could also be inside cluster or the wiring somewhere.
Old Nov 12, 2006 | 06:58 PM
deuce2ii's Avatar
Probably a little late here, but this happened to me, and it was because my battery needed to be replaced.
Old Nov 17, 2006 | 11:40 AM
raschul's Avatar
Thanks for the reply, I did the battery change out hoping that would help. Tried pulling the 11 & 15 fuses, still no help. It only happens when the outside temps are below ~50 degrees F. Then last till the car is warm.
audi4lyfe324
May 10, 2014 12:13 AM
Brandicb
Sep 2, 2009 09:02 AM
ChavmanII
Jul 17, 2008 07:24 PM
csnow_97A6_Quattro
Dec 10, 2007 08:05 PM
slimmj0k3r
Jan 30, 2006 02:16 PM
