Turning AWD to RWD??
Well I was sitting in the garage looking at my transmission and a silly idea popped into my head. Is it possible to turn the quattro into a rwd just by removing the cv shafts? Would the transmission stay balanced or would I have problems with the diff? It sounds too simple, so i'm sure there is a good reason why it can't be done. right?
In theory, I guess you can pop the CV joints and turn it into a RWD. But it will probably throw some codes related to ABS, ESP and etc.
I dare you to try. OOOh, a double dare!!
that pretty impossible..... if you remove the cv-shaft not only will u have open holes in the trans but the center diff is a pretty open diff. u would never get all the power to the rear unless u took the center diff out and some how made it a solid "closed" diff
Nevalite
Aug 13, 2012 03:04 PM
chesterfan1230
Apr 17, 2011 06:41 PM
