upgrade DV
Old Aug 27, 2007 | 05:57 PM
BOOSTME's Avatar
Default upgrade DV
i have a 2000 a4 with the 8lbs diverter valve what would be the advantages to putting an upgraded 14lbs diverter valve from audi into my car.......yes this is a serious question
Old Aug 27, 2007 | 07:39 PM
kraylon's Avatar
Default RE: upgrade DV
i think it takes a little more then just to upgrade the dv to go from 8lbs to 14lbs if your talking boost
Old Aug 27, 2007 | 07:43 PM
BOOSTME's Avatar
no i mean the spring inside the DV goes from 8 to 14 i just want to know what the advantages are to the 14 lbs spring
Old Aug 27, 2007 | 07:47 PM
kraylon's Avatar
are you able to run 14lbs from the turbo?
Old Aug 27, 2007 | 07:51 PM
BOOSTME's Avatar
don't know its a stock turbo
im running around 7 now
Old Aug 27, 2007 | 07:54 PM
kraylon's Avatar
if your not able to run 14lbs of boost and your not "chipped" then it will not be you any good to change the spring to 14lbs because you will not have enough pressure to open it
Old Aug 27, 2007 | 07:58 PM
BOOSTME's Avatar
ill have to find out whatt the stock turbo can handle then first so the spring rate in the DV will have more boost correct
Old Aug 27, 2007 | 08:02 PM
kraylon's Avatar
the stock tubo can handle 20 psi of boost but you need a chip to get 20 psi out of it if you just get a manual boost controller and turn it up you will go into limp mode and could damage the motor i run 18 psi of boost from a stock turbo and since i am chipped i have no problems.
Old Aug 27, 2007 | 08:04 PM
kraylon's Avatar
https://www.audiforums.com/m_535568/.../tm.htm#543444look here this is the diode mode kinda like getting chipped
Old Aug 28, 2007 | 03:46 PM
2k S4's Avatar
The DV should be matched to the boost of the car. If you put to high of a spring rate in the DV, it will not open all the way, & much slower. This will cause some boost lag, & slow spooling of the turbo.
Audi=Happiness
Apr 30, 2008 01:57 PM
stromo
Apr 23, 2008 07:21 PM
auditt225
Jul 20, 2007 03:56 PM
BadLuckAudi
Oct 14, 2005 02:30 AM
Dudek12
Oct 13, 2005 12:44 AM
