Voltage question HELP!!!
If you haven't fixed it yet, I have a suggestion. Older A8 have an electrical connection at the front right , just behind where the suspension is fitted to the car. With time it often falls to pieces, and from the symptoms you described, that might be where the problem lies. Let me know.
I would get a clamp on amp meter and measure what load you are seeing. Clampthe meteraround the positive wire on the battery. There may be some specified small amount of load, which would be good to know. If it is high, I would start pulling fuses untill it dropps off. To check the alternator, maybe disconnect the lead leaving it to see if the drain is beyond it. If the load is still there, try diconnect the lead to the alt. If it then drops off then most likley its shorted out. Good luck.
