Voltage question HELP!!!
Old Apr 13, 2007 | 02:45 PM
2k S4's Avatar
Default RE: Voltage question HELP!!!
ECU went to poop? I have nothing left for ya.
Old Apr 13, 2007 | 02:52 PM
techbod's Avatar
alternator
Old Apr 14, 2007 | 03:20 AM
mtm584's Avatar
Did you figure out what it was? Also what makes you think the alternator went out, just wondering?
Old Apr 14, 2007 | 07:09 AM
manin59's Avatar
If you haven't fixed it yet, I have a suggestion. Older A8 have an electrical connection at the front right , just behind where the suspension is fitted to the car. With time it often falls to pieces, and from the symptoms you described, that might be where the problem lies. Let me know.
Old Apr 15, 2007 | 12:50 PM
SloRide's Avatar
I would get a clamp on amp meter and measure what load you are seeing. Clampthe meteraround the positive wire on the battery. There may be some specified small amount of load, which would be good to know. If it is high, I would start pulling fuses untill it dropps off. To check the alternator, maybe disconnect the lead leaving it to see if the drain is beyond it. If the load is still there, try diconnect the lead to the alt. If it then drops off then most likley its shorted out. Good luck.
Old Apr 22, 2007 | 04:45 PM
manin59's Avatar
Have you solved the problem yet?
Old Apr 22, 2007 | 07:13 PM
CRAZYHAWK's Avatar
As avant80@2.6 said it could be the alternator. Diodes could be shorted,
also chech the voltage regulator.
sukisuru
Feb 11, 2011 01:53 PM
a6lovely
Aug 20, 2009 03:02 PM
ARIaudiS4
Nov 8, 2007 10:50 PM
y2karnival
Jan 19, 2006 06:55 AM
david9999
Jan 29, 2005 08:59 PM
