Will reverse, will not drive.
Old 08-31-2018, 10:42 AM
Patrick Thompson's Avatar
Default Will reverse, will not drive.
Hello!
I have an Audi A4 Quattro 3.0 from 2003. Awhile back after I got an oil change I noticed the car did not accelerate as it once used to. Didn’t really pay mind to it. However going to work today I pulled out of the driveway and the rpms were high and very sensitive yet the cars acceleration did not match it. And now the car will not move in drive, but acts fine in reverse. Any thoughts of where to start my search to get my audi back on the road?
Old 08-31-2018, 01:41 PM
JETSPEED333's Avatar
SoCal Crew Member
Check for any faults?
Old 08-31-2018, 06:39 PM
What faults are you referring to? Im sorry Im a little car illiterate. What do you recommend I look at?
Old 09-01-2018, 11:28 AM
SoCal Crew Member
We are looking for "Faults" or data stored in the Module respectively controlling that part. In this case probably the Transmission Control Module. A local auto place may be able to do that for you or anyone in your area (enthusiast or something) whom has a "Vag Com" I have my own and help people constantly.
Have you noticed any fluid leaks under your car?
Old 09-01-2018, 03:02 PM
No I have not, I plugged the reader into the car got the code P0343 which is the camshaft position sensor. Ive gotten two quotes one for $700 and the other $165...very confused.
Old 09-11-2018, 11:56 AM
SoCal Crew Member
16727/P0343/000835 - Camshaft Position Sensor (G40): Signal too High
Possible Symptoms
  • Malfunction Indicator Light (MIL) active
Possible Causes
  • Wiring from/to Camshaft Position Sensor (G40) faulty
  • Camshaft Position Sensor (G40) faulty
  • Timing misaligned
Possible Solutions
  • Check Wiring from/to Camshaft Position Sensor (G40)
  • Check Camshaft Position Sensor (G40)
  • Check Timing
virgiltu
09-15-2014 10:28 PM
gee_off2121
11-25-2009 10:31 AM
madman1234509
04-25-2009 09:40 AM
guru_king423
04-09-2008 10:45 AM
luvin_the_rings
12-21-2005 09:22 PM
Quick Reply: Will reverse, will not drive.
