windsheild washer fluid leak
Old Mar 15, 2009 | 04:58 PM
ckbkny's Avatar
Default windsheild washer fluid leak
Here's a new one, I'm getting a nice blue puddle forming under the driver's side front bumper. I've been going through a lot of washer fluid lately, thought it was just from heavy use during the recent snow. I'm assuming it's a leak in the windshield washer fluid plumbing for the left headlamp washer (always thought these washers were useless anyway) as I can see a trickle of blue fluid through the driver's side grill below the bumper.
Anyone else had this?
Any ideas on how to get in there and fix it?
Thanks
2002 A4 Avant 3.0 V6 Quattro
Old Mar 15, 2009 | 11:19 PM
Prizmatik's Avatar
If it is the the headlight washer, you will need to remove the front bumper. It isnt too difficult if you know where all the bolts are to remove it. Be sure to set aside plenty of time to investigate. Good luck!
Old Mar 25, 2009 | 10:07 AM
Blind92890's Avatar
I'm going to go ahead and shoot for the obvious. Should the the aforementioned post not work and you still have a leak, this problem happened on my 98 a4 tt 2.8; cracked washer fluid tank.
Old Aug 26, 2009 | 12:51 PM
bill0830's Avatar
My tank was cracked where the tank mount is located. I tried to reseal it, but still leaks. Guess a new tank is what it's going to take to fix it. I have been running around without washer fluid since buying my 2001 TT a year ago.
Old Aug 28, 2009 | 04:04 PM
bill0830's Avatar
Update for leaking washer tank. I took the tank out again and this time used "plastic" epoxy, which adheres to the plastic tank and bonds with the tank plastic. $4.99 later and tank no longer leaks. When I had the tank out, you can tell by the mount on the tank, it is mounted at a bad angle, which over a period of time will cause stress on the tank, which is where it was leaking. I can also see where the washer pump could cause this issue, but I siliconed the motor in place, just in case this was leaking also.. It is so nice having washer fluid in the tank and that washer tank low light OFF finally.
Davidiot
Apr 16, 2015 11:37 AM
mcanedo92588
Jul 1, 2013 11:27 PM
quattrojoe
Sep 11, 2012 01:02 AM
ckbkny
Mar 15, 2009 07:40 PM
benzodiazepine
Feb 24, 2009 12:27 AM
