Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Holding revs between gears (and more q's)
Old Jun 7, 2006 | 11:24 AM
4nick8's Avatar
Default Holding revs between gears (and more q's)
I have recently moved from a Nissan GTR to a 97 A4 1.8t 5-spd (mostly for the wife). I found all the A4s I test drove held the revs between the gears in a way I am not used to with any other turbo vehicle. Even MKIV golfs running essentially the same engine were significantly more punchy coming into boost.
I assume the A4 is designed to hold revs between gears to keep the turbo spooled. Is the turbo that antiquated that it can't handle the abuse of boost-vent-boost-vent....etc like almost all other turboed cars in the world?
Is it because the 1.8 uses a DV as opposed to a BOV? Is there a throttle body solenoid of sorts that slows throttle return? Can I remove it without harm?
What boost is considered maximum on the factory turbo and what is the likely point of failure when exceeding that?
(yea, I started searching and reading, I really did).
Old Sep 27, 2006 | 06:24 PM
311Style's Avatar
Default RE: Holding revs between gears (and more q's)
I noticed my 2004 S4 does the same thing but it is not turbo so I am wondering if anyone else has notcied this? Is this bad? Thanks
Old Sep 27, 2006 | 06:32 PM
techbod's Avatar
so whats your question
ORIGINAL: 4nick8
Old Dec 12, 2006 | 09:15 PM
ImTheDevil's Avatar
Default From what I've read...
...other cars, including the 07 Civic, do this as well, apparently as a way to help with emissions. I don't know really how this works to keep emissions down, but that's what I've heard. Any ideas, anyone?
Old Dec 22, 2006 | 12:44 PM
veeviii2003's Avatar
Default RE: From what I've read...
Yes it is for emmision purposes. At one point in the 80's I think there were certain model cars that couldn't be sold with a manual trans because they couldn't control the emmisions when the throttle plate slammed shut because you took your foot off the throttle to shift.
RagtagXMASTER
Jan 12, 2013 01:33 PM
Daveh366
Mar 3, 2011 12:43 PM
njs42002
Oct 5, 2006 07:26 PM
