Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
stage 3 exhaust question
Old Jan 14, 2010 | 09:40 AM
heywier427's Avatar
Default stage 3 exhaust question
hey guys. i wanna go stage 3 eventually, but i found a good deal on this exhuast:
http://www.magnaflow.com/02product/s...ne=all&id=7606
my question is, is it going to be too small for stage 3?
if i had to guess the diameter should be 3" from the turbo and dual out to 2.5.
or would it be ok to do 3" from the turbo, then swap out this exhausts downpipe to a 3" then adapt it down to the 2.25 dual out.
i found it for 350.00 plus my old one. sounds good to me!
does anyone have anything good/bad to say about this magnaflow set up?
thanks in advance.
Old Jan 17, 2010 | 10:54 PM
ImTheDevil's Avatar
All the magnaflow mufflers I've heard sounded really good on our engines. And the sizes you quote are more than enough for stage 3 airflow - that system should serve you fine as-is. I've seen tests where 3" was enough to flow 900hp worth of air, so I don't think you'd even need to alter that system at all - just bolt it up and go.
Old Jan 18, 2010 | 07:41 AM
heywier427's Avatar
thank you, thats what i wanted to hear!
so i should be fine with a 2.5 test pipe and this system down.
id like to achive at least 300 hp. im new to turbo motors and am under the impression bigger is better, thats why i ask.
thanks again.
spec-4
Jul 28, 2013 10:47 PM
holland3
Mar 19, 2011 03:20 PM
LowA4
Jan 15, 2009 06:59 AM
dubgli
Jun 27, 2008 12:42 PM
