Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Seat panel removal
Old Feb 8, 2015 | 10:42 AM
richie70's Avatar
Default Seat panel removal
How do you remove the driver’s seat backrest rear panel on a 2005 Audi Allroad C5. I need to access the backrest motor. Pictures would be helpful.
Thanks
Old Feb 11, 2015 | 01:25 PM
richie70's Avatar
Default Here's how.
Bentley gives you the basic idea on how to remove the back panel but leaves out 1 important item. The upholstery around the 3 sides of the panel have to be peeled out of the groove in the panel. There are 2 clips that have to be removed, these are under the bottom of the panel. They are plastic and depending on age may break but can be found at most auto upholstery shops. Once you have the clips loose then lift out and down with the panel. See some photos I have attached.
Hope this helps someone else.
Attached Thumbnails Seat panel removal-dscn3839.jpg   Seat panel removal-dscn3838.jpg   Seat panel removal-dscn3840.jpg   Seat panel removal-dscn3841.jpg
richie70
Feb 11, 2015 01:29 PM
richie70
Feb 11, 2015 01:28 PM
immusicman
Nov 2, 2010 08:39 PM
ugadawg24
Apr 4, 2007 06:01 PM
sharkbait
Sep 7, 2004 12:17 PM
