Audi A4 V6 1996 Door locking problems. Help Please!!
Old Apr 22, 2008 | 04:20 PM
Isramirez21's Avatar
Default Audi A4 V6 1996 Door locking problems. Help Please!!
Hello
I have a problem with the door locking. It doesn't work, I already checked the fuses, but seems like they're fine!
I don't know if there are more fuses located in the car that i haven't found!?
Can anyone give some advices on what the problem, could be? or can you tell me about a website where I can find a diagram to see where to check?
Any help will be really appreciated.
Thank you in advance.
Old Apr 22, 2008 | 04:41 PM
zippy_gg's Avatar
Default RE: Audi A4 V6 1996 Door locking problems. Help Please!!
ORIGINAL: Isramirez21
Hello
What do you mean by the door locking does not work? Are you using the fob, or are you using the key?
Different troubleshootying steps would apply for each...
Old Apr 22, 2008 | 05:20 PM
Thanks for your response.:-)
I mean the "Door power locks" doesn't work. yeah i can unlock it using the key.
I have manually to open the passager's door. I cannot use the remote to unlock it either:-(
thanks
Old Apr 22, 2008 | 07:51 PM
zippy_gg's Avatar
Have you tried to turn the key to the "Unlock" position and hold it for a few seconds. The remaining doors, trunnk, and gas cap should also unlock.
If this works then you may just have to reprogram your fob and you should be in good shape.
Old Apr 22, 2008 | 08:11 PM
CAB509's Avatar
6th Gear
I know the 96's key system is a vacuum system, so possibly you might just not have enough vacuum to operate the locks, I'm not sure where the pump is or what not but I would guess that should probably be looked at as a possible problem. Also if you post this in the A4(b5) section, you will get a lot more and quicker responses to your problems.
and welcome
Old Apr 23, 2008 | 02:24 AM
Yeah I've tried that but nothing happens. The trunk also is unlocked, I can't lock it even using the key ( it does close but it doesn't lock):-(
Thank you!
Old Apr 23, 2008 | 02:29 AM
Thank you for the help, I will post this question there.
Thanks!
a3turrell
Jun 4, 2023 11:15 PM
TrixieGirl
May 20, 2014 03:02 PM
panasonic999
Nov 19, 2013 04:52 PM
paythepiper
Nov 8, 2011 12:49 PM
Isramirez21
Apr 23, 2008 02:33 AM
