Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Turbo sounds - Looking to buy 2001 Audi TT
Old Mar 6, 2013 | 03:11 PM
CptCanuck's Avatar
Default Turbo sounds - Looking to buy 2001 Audi TT
Hi folks, newbie here so pardon the repeat questions. I found some threads related to this but need some help in layman's terms.
I'm looking at a beautiful 2001 TT Quattro, and took it for a spin. However the turbo doesn't whistle (should it?). Instead it makes a whoosh sound like a rush of air is being released.
Is this normal or is something wrong? Thanks for any help you can offer.
Old Mar 8, 2013 | 10:09 AM
Mike-2ptzero's Avatar
It shouldn't really whistle and is the whoosh sound you here when your on the throttle or when your lifting off?
Old Mar 11, 2013 | 01:40 PM
Idoccanada's Avatar
The turbo in a stock car will whistle but faintly you really have to listen for it unless the install is aftermarket (cone filter)
However the whoosh sound you are hearing (if its from lifting off the pedal or when shifting) should be the diverter valve/blow of valve which is releasing the unused boost from the turbo. THAT is normal, and what many people actually mod their cars for
Old Mar 12, 2013 | 10:47 PM
CptCanuck's Avatar
Thanks guys. The previous owner installed a boost controller and it looks like the setting was way off. It was demanding a boost at about 1000 RPMs, which resulted in a loud rush of air. The mechanic dialed it back and it runs really nice. Should I just remove this setup? I have no intentions of racing or using it at all.
Old Mar 13, 2013 | 07:59 AM
Idoccanada's Avatar
If you are bored and want to do it, sure. There is no disadvantage of having it there regardless of racing or not
BrettA601
Mar 13, 2014 09:32 AM
03a418tnate
Aug 10, 2010 08:07 PM
pologoped2
Oct 22, 2008 10:26 PM
bigrobby
May 30, 2007 02:46 PM
drkenan
May 30, 2007 09:03 AM
