RS Model Line Audi RS4 and Audi RS6..Pure race-car performance technology applied to the comfortable ride for which Audi is known
RS6 Leaking Water - Common Problem???
Old Apr 16, 2006 | 10:17 AM
NissanFreak's Avatar
Default RS6 Leaking Water - Common Problem???
Guys,
I pulled my car out of the garage the other day and hosed it down and I noticed water had leaked into the cabin from what seems to be through the cars plenum (where the ecu etc are located). I was told that this was a known problem does anyone know the fix????
Regards,
Old Apr 16, 2006 | 08:31 PM
AudiTech04's Avatar
Default RE: RS6 Leaking Water - Common Problem???
Make sure you drains in the plenum are clear or removed
If you lift the car slightly in the front and look where the steering rack is you will see some protruding rubber grommets, remove those
Old Apr 17, 2006 | 01:48 AM
AudiTech04: Thank you. So this is the common problem?
Old Apr 18, 2006 | 01:18 AM
AudiTech04's Avatar
Yes, leaves and such clog the drains
RobinJ
May 2, 2014 11:03 AM
Theghost_85
Nov 18, 2010 05:43 PM
rmA4
Jun 12, 2010 12:13 AM
rowemark
Dec 21, 2008 11:53 PM
hofmeister
Jun 3, 2006 01:40 AM
