RS6 Leaking Water - Common Problem???
Guys,
I pulled my car out of the garage the other day and hosed it down and I noticed water had leaked into the cabin from what seems to be through the cars plenum (where the ecu etc are located). I was told that this was a known problem does anyone know the fix????
Regards,
Regards,
Make sure you drains in the plenum are clear or removed
If you lift the car slightly in the front and look where the steering rack is you will see some protruding rubber grommets, remove those
hofmeister
Jun 3, 2006 01:40 AM
