1/4m Track time
hey guys ran the car at the the track for the first time last night here is my best run
rt .331
60 ft 1.951
330 ft 5.854
1/8th 9.030
1000 ft 11.667
1/4m 13.864
mph 103.34
i kept haveing a an issue with traction control engaging and bogging the car from first to second any suggestions as to how to turn it off or dissable esp all togeather my car is a 00 s4
rt .331
60 ft 1.951
330 ft 5.854
1/8th 9.030
1000 ft 11.667
1/4m 13.864
mph 103.34
Yeah, you see that unlabeled button next to your fog light switch...thats where it is on the newer models. I dont have any problem in my 2k S4 launching at a 5k clutch dump(dont do it if you have the stock clutch) and if the ground is wet I can spin all four tires. https://www.audiforums.com/forum/sho...d.php?t=110722
realize the esp deal talked to Jason at jhm yesterday he said that it wasnt esp cause i dont have it but that it was actually the traction control sytem applying brake preasure to the rear wheels when sliping is detected and his fix for past customers was to remove the abs pump fuse wich i tried yesterday in an empty parking lot. this seemed to have fixed my issue i will find out next week at the track but after removing the abs fuse it did not buck and kick like a fricken horse shifting from 1st to 2nd and nose dive instead it was pretty predictable with slight wheel spin in first and a nice chirp going into second and third he said that only the 2000 models were affected by the intrusive traction control sytem and that the 01+ models have the dissable button like you guys stated
also i was a little sceptic about the clutch setup im running but after hammering on it at the track for the first time im a believer i pounded on it at 4 and 5k launches run after run with no problems still getting used to the all wheel drive feel i am loving this car more and more
