2001 S4 Problem...Please Help!!
Old Sep 6, 2005 | 09:58 PM
s4stunner's Avatar
Default 2001 S4 Problem...Please Help!!
Hello all. I purchased a 2001 S4 about a month ago, 59,000 miles. I have been having an intermittent problem under acceleration that hopefully someone will be able to diagnose. In 2nd sometimes and 3rd mostly the car hesitates under accelleration, surging around 3k-4k rpm, then taking off. In 3rd gear this is usually accompanied by a CEl, that flashes at first then either stays lit or goes away, it doesn't seem to be consistent. As far as I know, the car is stock. There is a AWE boost gauge in the vent, but the diverter valves and TBB look stock. I don't know about the computer. This is a really annoying problem as it leaves me with little confidence in the car. Please help. Thanks.
Old Sep 6, 2005 | 10:05 PM
s4stunner's Avatar
Default RE: 2001 S4 Problem...Please Help!!
That post didn't make a whole lot of sense. When I had my WRX I had a similar problem when we replaced the IC. The car would boost until a certain PSI, then just surge and feel like it was dragging. The S4 does the same thing but the boost picks back up.
Old Sep 8, 2005 | 11:15 AM
s4stunner's Avatar
Someone else has to have had a similar problem or an idea. Are the above symptoms related to the Throttle Body Boot? The diverter Valves?
Old Sep 10, 2005 | 08:39 PM
Slow S4's Avatar
my '01 does the exact same thing. i have been searching all over different forums trying to find someone else who had that problem. i was told that it could be my TBB so i checked it and it was blown so i replaces it with a silicone one thinking that would fix it. it didnt. i have hyperboost DV's so it is not them. then i was told that i could have a bad fuel pump so i replaced that too, still didnt fix it. i thought it might be aboost leak somewhere else so i got a full silicone hose kit when i got my turbo upgrade and was sure that would fix it, but once again i was wrong. the best i can figure is that it is my injectors. i got the stratmosphere stg. 4 so i still have my stock injectors. i havent done anything about it yet but it is drivng me nuts. if you figure out what the problem is make sure post it soon.
2001 TT Don
Aug 11, 2012 10:15 AM
stevers21
Jan 20, 2010 08:53 AM
jmillerc2
Aug 29, 2008 01:31 PM
TSMS4
Apr 9, 2008 11:28 PM
garibaldi
Apr 13, 2007 12:51 AM
