b5 s4 serpentine belt replacement advice needed
Old Feb 27, 2006 | 09:23 PM
balu's Avatar
Default b5 s4 serpentine belt replacement advice needed
I am trying to put a new belt on my car but maybe I don`t do something right because I can`t, I loosened the pulley and I am short on the belt,it might be that I am trying it the wrong way,I got the car with the belt cut,so I cannot see the original way,or maybe I need to loosen the alternator as well?any help pointers appreciated
thanks
Old Feb 27, 2006 | 09:35 PM
Jestnomen's Avatar
6th Gear
Default RE: b5 s4 serpentine belt replacement advice needed
Have you read this??
http://www.audiworld.com/tech/eng63.shtml
Old Feb 27, 2006 | 09:48 PM
balu's Avatar
thanks for the link,you mean I cannot replace the serpentine belt without taking the whole front off,i am not doing timing belt.
Old Feb 28, 2006 | 03:07 AM
dankhound's Avatar
You should be able to sneak the belt without removeing the front end. Removing it will make things much easier thou. You dont have to loosen the alternator at all. You may not have the tensioner fully tensioned or it may be broken. Possible cause of broken belt. I would also make sure you have the right belt. You may also be routing it incorrectly. Usually its way short or way long when that is the case thou.
Old Mar 1, 2006 | 08:49 AM
balu's Avatar
thanks guys the problem is solved as usuall wrong part(belt),now all is OK,with the belt lots of work left
Neosapian
Mar 25, 2014 09:55 PM
tpkg
Mar 1, 2013 12:10 PM
Timon
Jul 7, 2012 01:29 AM
Rodmar
Jan 27, 2012 05:05 PM
BaldySA
Aug 15, 2009 07:59 PM
