B5 S4. What else to replace when doing the clutch/flywheel
Old Apr 3, 2011 | 11:22 PM
allwheeldriven's Avatar
Default B5 S4. What else to replace when doing the clutch/flywheel
I am about to replace the clutch and flywheel in my B5 S4 and was wondering if there were other things that should be replaced at the same time so I can go ahead and order the parts.
Thanks,
I'm going with a Vast stage 3 and aluminum flywheel. Car is stock otherwise.
Old Apr 4, 2011 | 01:30 AM
Reiem125's Avatar
If you have both the engine and tranny out and you have the money go stage 3. But if not I guess you could do mounts, gaskets, timing belt and water pump, pulleys and so on. It really depends on what your plans are for the car and what your budget is.
Old Apr 4, 2011 | 06:27 PM
So does the engine need to be pulled to change the clutch?
I'm not really sure what I am going to do yet as far as mods. It has 100k on it but has been well maintained.
But figured I'd get a clutch that can handle whatever I end up throwing at it just in case.
Old Apr 4, 2011 | 08:36 PM
VAST Performance's Avatar
First off, Thank you for choosing our Clutch & Flywheel. I personally designed our new Clutches & the stage 3 will be more clutch then most will ever need.
You do not have to pull the motor to do the clutch & flywheel.
I would change the trans mounts while your under there, more then likely once you install this clutch you won't be going back under there for a long time.
So you might as mell change the mounts.
Old Apr 7, 2011 | 02:20 PM
jamestown478's Avatar
maybe slap on an awe drive train stabilizer bar when you do the mounts too since its in the same area.
Old Apr 7, 2011 | 03:58 PM
SilverAudiS4's Avatar
wait let me get this right, you DONT have to pull motor and transmission to change clutch?
Old Apr 9, 2011 | 02:20 AM
no you can drop just the transmission to change the clutch. Some people find it easier to pull the motor and tranny out together though.
Old Apr 9, 2011 | 10:37 PM
Nice so I'll know who to mail my tears to if the clutch doesn't last. This is the last time I want to have this stuff out.
j/k I have read nothing but good things about it and can't wait to get it in I'll be ordering the mounts also.
Hmm, not sure if this is worth it. From what I've read some say yes some say no.
Old Jun 9, 2013 | 04:16 PM
Cody H's Avatar
Red face im changing me clutch as well
ok so kinda been looking every were to find help on this, is it going to be easier to pull the motor or drop the trany i just dont want to spend days doing this, going from stock to stage 2 spec clutch and 9lb aluminum fly wheel
96quattro2.8
Mar 13, 2013 09:41 AM
lemhead16
Aug 27, 2007 10:50 PM
nabujam
Jun 29, 2007 02:25 PM
