Brake fluid
Is there a different process compared to your average vehicle that you have to do when bleeding the brake fluid on a B5 S4?
Thanks for any input you may have!
Bleed with the car off starting with passenger rear, then driver rear, passenger front, then driver front, then the slave.
you might have to cycle the ABS pump if it went completely dry
Ross-Tech: VAG-COM: ABS Brake Pump Bleeding
n_gunjan
Mar 8, 2010 05:05 PM
