cam adjuster gasket leak?
Old Nov 25, 2005 | 07:12 PM
techbod's Avatar
Default RE: cam adjuster gasket leak?
this I don't understand ( how does it leak through the cam cover seal?? ) the adjuster is internal to the cam cover please explain
Old Nov 25, 2005 | 07:14 PM
techbod's Avatar
I'm not into this engine so very interested
Old Nov 25, 2005 | 07:16 PM
techbod's Avatar
I still think this is a rocker cover gasket issue
Old Nov 25, 2005 | 09:22 PM
techbod's Avatar
checked all my files and not happy with the answers so far, its a scam in my view "pictures required" with rocker covers still on showing oil leak and data showing valve timing/pressure loss
Old Nov 25, 2005 | 11:46 PM
AudiTech04's Avatar
Its not an internal leak like i think your thinking of
It leaks out the back of the gasket
See the adjusters sit on top of the head at the rear there is a gasket between that leaks on to the back of the head
Old Nov 26, 2005 | 06:22 AM
techbod's Avatar
now I'm getting the picture, correct me if I'm wrong "camshaft end seals" and my thoughts were on the cam chain tensioner
Old Nov 26, 2005 | 03:15 PM
AudiTech04's Avatar
ORIGINAL: avant80@2.6
Bank 1 has the "end seal" at the front and is the rear on Bank 2 those have also been known to leak but not as much at the tenisor
Old Nov 26, 2005 | 05:40 PM
  #18
lewishw's Avatar
so what is the verdict? warranteed or not?
Old Nov 26, 2005 | 06:56 PM
  #19
AudiTech04's Avatar
There are many different aftermarket warranties so it always varies
Plead your case and find out
Old Nov 26, 2005 | 07:53 PM
  #20
Ted's Avatar
Ted
It should be under warrenty. And the Water leak is prolly still leaking, but it never really looks like it, just that pink crud that builds up around the leak.. The oil leaks are allmost allways coverd under warrenty. Good luck
timmay074
Nov 18, 2009 12:29 AM
twinturbosixer
Jun 7, 2009 12:09 AM
Asianicestyles
Jul 17, 2008 01:26 AM
icanhas4wheeldrift
Aug 9, 2007 11:35 AM
