clutch problems
Old Nov 29, 2005 | 02:58 PM
Santorin2k2's Avatar
Default clutch problems
I have a 02 6 speed and with the engin running and the clutch pushed in it will not go into gear. When the car is off i put it into gear and held the clutch in to start the car when it started with the clutch in it would start to go but i could not get it out of gear until the car was off. i know i need a new clutch and was wondering which clutch to use and if i should put in a light weight fly wheel or oem. i have an apr chip, bi-pipe, intake and plan on other performance up grades. also how much would it cost to get installed.
Old Jun 5, 2006 | 05:34 AM
E46eater's Avatar
Default RE: clutch problems
man, I feel you man, I have the same problem right now too. Im just hoping its not my clutch but the master cylinder.
Old Jun 5, 2006 | 08:09 AM
techbod's Avatar
probably the slave cylinder on the gearbox needs bleeding check your break fluid level it feeds the slave cylinder
Old Jun 5, 2006 | 06:27 PM
Mott Power's Avatar
Hano had the same problem. Ended up being a loose bolt holding the shift linkage in. So check that out, too.
phila19146
B8 Models
Dec 22, 2010 02:35 PM
pullacowonaski
Mar 27, 2009 12:00 PM
s4raf88
Jun 16, 2007 01:41 PM
SamJamaica
Jun 13, 2005 02:07 AM
