compression test
Old May 7, 2009 | 12:14 AM
DSMKiller's Avatar
Default compression test
So with my cylinder #2 misfire issue. I called the local shop to get a diagnose of my electrical system. Its 95 bucks, but does not include a compression test. So should I do a compression test before I bring it to the shop to tell me that my ICMs are bad (Im 90% sure), but want to be exact before I start buying parts. So my question is, is the compression test just done my replacing the plug with the tester and turning the car over or let it run?
Ryn
Old May 7, 2009 | 12:24 AM
drev500@aol.com's Avatar
ya but you need to throw in anextra step and disable the ignition and fuel so your not dumpin fuel in and igniting it. Also just turn the car over for about 3 sec.
Old May 7, 2009 | 01:12 AM
DSMKiller's Avatar
So how do you disable the ignition and fuel?
Old May 7, 2009 | 01:32 AM
Midniteoyl's Avatar
Pull the connectors on the injectors and pull the plug wires.
Old May 7, 2009 | 04:05 AM
bottlecap's Avatar
quick and dirty just pull the fuse for the fuel pump, turn the car over a couple times to burn the extra fuel in the lines and you're good to go. the norm for a compression test is 4turns of the engine. its best to have a battery charger hooked up so each cylinder gets the same amount of cranking power for the most accurate numbers
Old May 7, 2009 | 06:36 PM
bigern45's Avatar
so your paying 95 bucks for a diagnosis .. but.. if its not fuel or ignition, they ARENT going to find out the problem??? where im from a diag is a diag.. maybe you should ask for a drivability diag... includes fuel pressure test, compression test and ignition test.. i hope they know what they are doing.. and anyways.. every real technician knows the first step in drivability diag is making sure everything is mechanically sound before looking into fuel or spark.. so a diag should include a compression test.. or a cylinder leakdown test or a car running vacuum test..
magicturtle2
May 9, 2014 10:32 PM
DOC_DEPALMA
Oct 4, 2011 06:33 PM
Dallas09
May 1, 2009 04:41 PM
khj677turbo
Nov 21, 2007 11:15 PM
wood_e
Nov 7, 2006 06:35 PM
