Could leaking vac line= P0300 Random misfire?
I get one every few hundred miles, usually when the car idles for longer than normal time periods.
I've recently changed:
-coilpacks.
-spark plugs.
-air filter.
Mods:
-APR cat-back;
-pig taled downpipes.
-older GAIC chip.
I tried to figure this out a while back but all I could come up with was:
-maybe do a new fuel filter.
-it was the rougher idle of the chip that might be causing it.
-I did have a bad vacuum connection at my old boost gage, but thought it was fixed.
-coilpacks.
-spark plugs.
-air filter.
Mods:
-APR cat-back;
-older GAIC chip.
Hopefully I can rule that scenario out. After I changed the plugs and coils I let the car idle for several minutes. I gave it a rev here and there. The CEL eventually came back on. I erased it. A week or so later I removed the plugs to inspect them and they looked good.
I have been working on this problem for about 5 months. I replaced first I was getting a misfire on 4 then after sparkplug swap misfire on 2. Moved the coil pack to 3 and got misfire on 3. Replaced the coil pack and now random misfires.
I did replace my boost hoses a few moths ago just before this problem started. (Had a hole in a boost hose)
This brings up a thought anyone done a pressure test to confirm that there are no boost leaks. I keep thinking that a misfire is caused by
1 not enough fuel
2 not enough air
3 not spark
4 or spark at the wrong time
I am going to try this latter this weekend and see if I find a leak.
Let you all know what I find
1 not enough fuel
2 not enough air
3 not spark
a4sport
Oct 27, 2006 11:02 AM
