Could leaking vac line= P0300 Random misfire?
Old Jan 13, 2010 | 05:35 PM
Meanstreak's Avatar
Default Could leaking vac line= P0300 Random misfire?
I get one every few hundred miles, usually when the car idles for longer than normal time periods.
I've recently changed:
-coilpacks.
-spark plugs.
-air filter.
Mods:
-APR cat-back;
-pig taled downpipes.
-older GAIC chip.
I tried to figure this out a while back but all I could come up with was:
-maybe do a new fuel filter.
-it was the rougher idle of the chip that might be causing it.
-I did have a bad vacuum connection at my old boost gage, but thought it was fixed.
Old Jan 13, 2010 | 09:14 PM
bottlecap's Avatar
i have that same code and im still scratchin my head, let me know if you find out
Old Jan 13, 2010 | 11:59 PM
bigern45's Avatar
yes it will cause it.. if youre running lean, then your ecu will correct with an extremely rich fuel/air ratio, and after driving it for a while it will foul out your plugs and you will start to misfire..
Old Jan 14, 2010 | 07:04 AM
Meanstreak's Avatar
Hopefully I can rule that scenario out. After I changed the plugs and coils I let the car idle for several minutes. I gave it a rev here and there. The CEL eventually came back on. I erased it. A week or so later I removed the plugs to inspect them and they looked good.
Old Mar 31, 2016 | 03:07 PM
william.boy4@gmail.com's Avatar
Default P0300 and p03??
I have been working on this problem for about 5 months. I replaced first I was getting a misfire on 4 then after sparkplug swap misfire on 2. Moved the coil pack to 3 and got misfire on 3. Replaced the coil pack and now random misfires.
I did replace my boost hoses a few moths ago just before this problem started. (Had a hole in a boost hose)
This brings up a thought anyone done a pressure test to confirm that there are no boost leaks. I keep thinking that a misfire is caused by
1 not enough fuel
2 not enough air
3 not spark
4 or spark at the wrong time
I am going to try this latter this weekend and see if I find a leak.
Let you all know what I find
Armenian
May 29, 2017 02:37 AM
xx00A6xx
Apr 2, 2012 11:24 PM
KoolMan
Dec 9, 2011 12:03 PM
bandaru37
Dec 10, 2008 10:39 AM
a4sport
Oct 27, 2006 11:02 AM
