Holds boost but low Vac
Old Aug 7, 2009 | 04:10 PM
digdgb's Avatar
Member
Default Holds boost but low Vac
My car recently is only displaying 10 inhg. Car runs good at idle. Dont have a vag cable yet to check. I assume i have a vacuum leak. Im not sure where\ and how(other then looking at line) to check for a leak.
Old Aug 9, 2009 | 02:40 PM
thareals4's Avatar
what is 10inhg to PSI or bar?
Old Aug 9, 2009 | 02:47 PM
bottlecap's Avatar
did you make sure your boost hose isnt kinked or loose? vacuum isnt measured in psi or bar on most gauges. i think mines around 20inhg at idle tho so his isnt sucking as much as it should
Old Aug 9, 2009 | 08:41 PM
thareals4's Avatar
ah i see.
Old Aug 10, 2009 | 03:54 PM
digdgb's Avatar
Member
I will check connections thanks
texaspete
May 10, 2017 02:43 AM
ImTheDevil
Feb 19, 2008 03:07 AM
aRIf
Nov 1, 2006 05:42 PM
Jamo303
Mar 25, 2005 10:42 AM
