Need some help with misfiring
Old Mar 3, 2012 | 02:38 PM
Billydakid's Avatar
Default Need some help with misfiring
I'm lost with a few things ???
Ok here's the deal I just put a new motor in. I used my original head that I had rebuilt because of a broken timing belt. Then I let my sister drive my car and she blew rod threw the block . But anyway the car runs and drives but, it's shows multiple cyclinder misfires on the scan. Would the timing being of a tooth or two be the cause of this misfiring and running like poop? Also the white wire with a red stripe off the upper oil pan were does that plug in to. It's a single male square plug on the end I can't figure out ... I'm bashing my head off the wall trying to figure this out ????
Old Mar 3, 2012 | 02:57 PM
FonzoB5S4's Avatar
you might need to replace your coil packs for the misfires.
Old Mar 4, 2012 | 11:08 AM
Billydakid's Avatar
Already tried that:-/
Old Mar 4, 2012 | 01:03 PM
02A6Beau's Avatar
pull the front off and verify the timing. could be cam position sensor, but that should throw a code. could be a vac/MAF problem, but that should throw a code
Old Mar 6, 2012 | 12:52 AM
JETSPEED333's Avatar
SoCal Crew Member
no codes? ...check spark plugs? gap....
Old Mar 6, 2012 | 03:53 PM
duplago's Avatar
When you drive it will it go past a certain RPM or speed? A timing issue definitely sounds like a good possibility. I would pull the front off and check the timing for sure.
Old Mar 11, 2012 | 05:56 PM
SoCal Crew Member
compression test
Old Mar 11, 2012 | 07:57 PM
shelleytj's Avatar
My A4 has a misfire as well. Checked the coil packs...they were fine. Mine gave off codes
P0303, P0299 and P0011. Any help would be greatly appreciated! Thanks
cncbamf
May 9, 2017 05:39 PM
googlegot
Jun 10, 2012 06:25 PM
tketke
Nov 4, 2008 12:01 PM
limptimtim
Mar 16, 2007 11:21 PM
nitro_rider2001
Feb 27, 2007 07:39 PM
