not starting
Old Jun 6, 2008 | 10:00 AM
alxjhn's Avatar
Default not starting
i have 2000 S$. the car is not starting. the fuel pump is not coming on. i changed the fuel relay. What other problem can cause the fuel pump not to work.
Old Jun 6, 2008 | 10:21 AM
meatbiscuit's Avatar
Default RE: not starting
Are you sure the fuel pump actually works?
The fuel pump has it's own fuse as well I believe. Check the manual, but it should be number 28. See if the fuse is fried.
Old Jun 6, 2008 | 11:36 AM
readimag's Avatar
plus the whole pump may have gone ut also I would just pull it and see after putting in a new fuse.
Old Jun 6, 2008 | 12:42 PM
CamoA6's Avatar
Pull the pump and check you powers and grounds. Make sure you really have no fuel pressure.
Old Jun 7, 2008 | 01:26 PM
doofness's Avatar
ORIGINAL: alxjhn
I don't know maybe it's possibly, dead
Old Jun 7, 2008 | 02:40 PM
derek072887's Avatar
do u have to drop the tank to get the pump out or can u just pull up the back seat like some cars??
Old Jun 7, 2008 | 04:30 PM
Reiem125's Avatar
I believe you can access the pump through the truck area. There is also a puel pump relay you might want to check.
Old Jun 7, 2008 | 08:20 PM
Mott Power's Avatar
how'd you find out it was the fuel pump?
makhack
Jun 23, 2011 12:42 PM
Audcura
Mar 9, 2010 11:48 PM
jojoenglish85
Feb 2, 2009 03:30 PM
Honda882000
Dec 27, 2007 10:37 PM
doubleDee
Sep 18, 2007 07:27 AM
