oil leak
Old Jun 12, 2007 | 07:30 PM
ahwest's Avatar
Member
Default oil leak
hi all,
im having oil leak problem, most of the time i smell some burning oil cold start in the morning, also sometimes in slow traffic. I was told that the valve cover gaskets need to be changed, i dont think i will have problem changing the valve cover gaskets. However the guy from Miramar Audisuggested me that i should change the cam tensioner gasket as well since they go bad easily. So i did some research on this matter, and i couldn't really find the answer, some say it's not that difficult to do some say it requires special tool to complete this job. Is there really a DIY article that i can follow with?
If i need a special tool, where can i get it?
This is the only article i found, it is not specified with S4 but a 2.8L and the step-by-step procdure is not very detail and clear.
http://www.robsaudiworld.com/2.8camseal.htm
thanks
Old Jun 12, 2007 | 09:53 PM
S obsessed's Avatar
Default RE: oil leak
I pulled and installed the cams without the tool but you have a great risk of damaging the bearing surfaces of the cams and possibly wrecking the chain if not carefully done. Also there are many sharp edges to cut yourself on if you are fighting the spring pressure of the adjuster/tensioner. You just have to be clever and resourceful and you could do it without, however if the tool is cheap buy it. I never even checked I just did it. The 2.8 head is basically the same. good luck
Old Jun 12, 2007 | 11:07 PM
ahwest's Avatar
Member
so you just pull up the chain for the clearance to take out the old cam tensioner seal and put in the new one?!
Old Jun 12, 2007 | 11:23 PM
S obsessed's Avatar
I did it to pull the intake cam out not the adjuster gasket but You may have enough room just making slack and sneaking gasket in place. Make sure surfaces are clean of course. If you don't have enough room just pull the intake cam up and out of the head and you will then have the room you need. It is a bitch but can be done. The chain slack is definately neccasary.
Old Jun 13, 2007 | 09:10 AM
CamoA6's Avatar
you can do without the tool if you pull the cams I know. I saved myself from pulling the cams with the tool . looks like a piece of plastic and a bolt through it...hard to explain I geusss
Old Jun 13, 2007 | 11:38 AM
GeilKyle2's Avatar
http://www.ca-va.org/tech/camtensioner/index.html, if you pull the cam.
Octane567
Aug 8, 2014 10:28 AM
vtraudt
Feb 25, 2012 11:09 AM
mikeeboy82
Jun 13, 2009 11:09 PM
inventorA6
Apr 15, 2009 06:46 AM
