oil leak near turbo and power loss
Old Nov 9, 2008 | 08:59 AM
xxbmxlsxx's Avatar
Default oil leak near turbo and power loss
it looks like my b5 has an oil leak near the drivers turbo. when im on it hard i do smell oil. do i have to pull the engine to check my turbos? the oth er thing is my car has lost some of its topend power. i have apr software and straight pipe exhaust. car has 50,xxx miles on it. tb boot looks good. new divertors. what could be causing this. it kind of stutters a little in high gears and bucks real hard when you let off the gas.
Old Nov 9, 2008 | 09:32 AM
bigern45's Avatar
id check your valve cover gaskets and your cam plug on the driver side.. that was all leaking bad on mine.. i also had to do cam seal adjusters.. pretty big job but i did them all at once so that i will not have to worry about any of it..and stutters like mis-fire ?? u may just need a tune up.. dunno if we have a communication break down or what..
Old Nov 9, 2008 | 01:23 PM
xxbmxlsxx's Avatar
not misfire. i have all new coils and plugs. feels like boost leak but cant hear a leak. do i have to pull the motor to do those things?
Old Nov 9, 2008 | 01:50 PM
xxbmxlsxx's Avatar
well i guess it doesnt feel like a normal misfire anyway.
Old Nov 10, 2008 | 10:06 PM
drev500@aol.com's Avatar
make a leak tester. Look on AWE tuning they have one for sale or you can make one. It hooks up to the intake Y pipe. As for doin the seal, gasket, and adjuster, you dont have to pull the motor. Get a bently manual if you do decide to do that work yourself. Its worth ts weight in gold and then some.
Old Nov 11, 2008 | 01:12 AM
bigern45's Avatar
i took the y intake pipe out and then took two small aerosol cans (battery protector from permatex i think) and put them and clamped them in the turbo inlet intake tubes.. or whatever their called.. then i took out the boost sensor in the tbb and shaved on a valve stem until it fit pretty perfect and held it in tight.. blocked off the acordian style pcv hose that goes to the y intake pipe and added pressure with an air chuck.. but i only did this because i couldnt wait till i got my pressure tester from awe..lol..
Old Nov 11, 2008 | 09:36 AM
xxbmxlsxx's Avatar
debating getting a new coupler kit and or getting this intercooler setup
http://cgi.ebay.com/ebaymotors/ws/eB...=280283228758g
blk281gt
Aug 14, 2012 11:35 AM
a_emblin
Jan 10, 2007 04:44 PM
Purple Broom
Sep 17, 2006 11:01 PM
Purple Broom
Aug 7, 2006 09:36 PM
cbrstu
May 12, 2006 07:28 PM
