proper launch rpm
Old May 6, 2005 | 04:32 PM
SP4NK3R's Avatar
Default RE: proper launch rpm
Absolutely, I'm finding that to be the case also. To do the higher launch( 4 to 5) I've found that I'll start letting the clutch out in that 4 to 5 range, but by the time it is fully out, I let the rpms drop to the lower 3 range (insert light feathering here), anything else would require a clutch upgrade. You know, if you are doing this often, it's going to seriously degrade the life of the involved componants. Learn how to do it and then do what "abacab" does and "launch" at 900.
Old May 6, 2005 | 05:04 PM
alex verve's Avatar
ORIGINAL: abacab
I like to 'launch' at around 900rpm
easiest launch is simply let clutch go slowly at idle without touching acceleration pedal. car will launch by itself no prob, even with extra passenger in a car. i did it even in 2nd gear, but only me in a car...
Old May 9, 2005 | 05:32 AM
chiman414's Avatar
thanks for the input guys
ORIGINAL: SP4NK3R
sp4nk3r, i'm not doing that often, and to be honest, i think in the entire 8 months i've had the car, i think i've really taken off once...and that was when i had teh car a couple weeks and my friend just wanted to see how his car kept up...i don't do all that street racing stuff too risky for me, i just stick to driving intoxicated! jk...
thanks again for the input guys
-raj
Old May 10, 2005 | 12:13 AM
apg96's Avatar
ORIGINAL: EddieS4
ORIGINAL: Jestnomen
3500-4000 rpms is a good range.
Uhhh...Okay, I realized you don't even own an S4. If you did in the past, you definitely did not understand its powerband (and physical strength limitations).
The S4's peak torque begins at 1850 (stock) and stays with ya for quite a while... I would probably launch at 2000 ~ 2500 RPM at the highest.. No need for any higher than that, unless you can afford a new tranny or rear differential. If your upgrades include bigger turbos and you have strenghtened the drivetrain, you could always go a little higher than that to stain within the powerband.
Launching an AWD car at anything higher than 3500 RPM is risky business. The amount of stress this places on the drivetrain (it actually causes the driveshaft to twist out of specifications) can cause serious damage. For best performance, you should always learn your powerband and decide from there. There is no "static number" and it varies from car to car.
I cant believe he said that to u jest. WTF. No respect from the noobs. OO well, i would launch at around 2500 unless u want to burn ur clutch (if ur good u cnat prevent this). I would launch at like 3500 but i would buy a better cluthc like a stage 3 or a RS4 clutch. And lighten ur flywheel.
obd2toolbar
Jun 24, 2015 12:06 AM
BobbyB50
Jun 11, 2011 08:28 PM
Armenian
Aug 29, 2010 11:27 AM
hhh1855
Jul 3, 2009 09:44 AM
jmac2876
Aug 28, 2006 03:26 PM
