Questions on Wheel Offset
Old Jun 26, 2007 | 07:34 PM
oshburg's Avatar
Default Questions on Wheel Offset
I bought some HP Evo wheels online. I talked to the distributor and he said they would fit my car. When they arrived it says the offset is 31. How will this work out if stock offset is 35?Just spacers? If so do they make hubcentric spacers this small?
Old Jun 26, 2007 | 09:48 PM
TKneedsS4's Avatar
Default RE: Questions on Wheel Offset
yearrrr spacers maybe even new rims... sorry to say but with a decent spacer you should be right on. what size are wheels u may need to roll fenders if you drop it or have 19's
Old Jun 26, 2007 | 10:08 PM
oshburg's Avatar
Wheels are 18x8. I went with 235/40/18 for rubber. It is not lowered yet, but if it is sitting like a monster truck after the new wheels/tires go on I am going to be getting coilovers.
If I need spacers, do they make hubcentric spacers this small?
Old Jun 26, 2007 | 11:00 PM
2k S4's Avatar
Try it, offset will change with rim size & type. They may fit fine, or you may need a small spacer.
Old Jun 27, 2007 | 12:51 PM
sooks's Avatar
YEah..you might need a spacer... Offset is wheel dependent..but thats pretty low on the S for offset...
also, stock offset is like 42 i thought?
Old Jun 27, 2007 | 01:29 PM
joshpsu's Avatar
yes stock is up in the 40 range for sure. Usually with 18" wheels anything between 33-38 will fit ok, 31 is a bit too low and you might need spacers. If the wheels were "gauranteed" to fit your car when you bought them, and they dont fit when you get them, then you should be able to give them back free of charge since they lied to you. If you bought it from a private owner, then you will have to make due
quattrolove
Apr 29, 2016 04:23 PM
jupwood21
B7 Models
Jul 10, 2010 08:46 AM
audiRSallroad
Jul 6, 2008 01:49 AM
audiboy429
May 9, 2007 02:05 AM
18valvesbehind
Feb 23, 2007 05:33 PM
