screeching sound from wheels..!!
Old 11-30-2007, 01:42 AM
slvr_S4's Avatar
Default screeching sound from wheels..!!
please help me ...every time i turn out of my driveway...or make sharp turns my wheels start to make screeching sounds...what is that sound...is it the wheel bearings...does that effect the perfomance of anything on the car???
Old 11-30-2007, 10:42 AM
BLUE RENEGADE's Avatar
Default RE: screeching sound from wheels..!!
If it only happens when u make Semi Sharp turns then its your power steering , I.E.belt to lose , not enough fluid
Old 11-30-2007, 10:43 AM
rmt99e's Avatar
Check your power steering fluid, or it may be power steering pump. Mine level was low, it wasn't screeching, but it was definatly making noise. Added some fluid and was good. If you do find your fluid level is low, you have to get a certain type of pwr steering fluid.
Old 11-30-2007, 10:55 AM
is your drive way smooth? it could be tyre noise on the ground, power steering ? easley checked apart from the fluid level ( start the engine and do a lock to lock on the steering wheel if it squeals then its the belt/fluid and the rest I wont mention before a week end
Old 11-30-2007, 10:57 AM
meatbiscuit's Avatar
This might sound trivial, but I had a similar problem. Turned out, after taking off the wheel, there was a rock stuck in between the backing plate and the rotor. When my wheels were turned at certain angles, it made a nasty screeching noise.
I know it sounds too easy, but it's worth taking the wheel off and having a look.
Hope this helps.
Old 11-30-2007, 12:30 PM
CamoA6's Avatar
also see if the backing plate is hitting the wheels or brakes. take a screw driver and push it back if it is.
Tel
05-13-2014 03:29 AM
nova_ss672001
11-10-2008 07:11 AM
TiredOldMan
10-08-2008 02:18 PM
a3atx
07-06-2008 08:30 PM
vigorcomp
04-14-2006 02:45 AM
Quick Reply: screeching sound from wheels..!!
