Seatbelt warning sound
Old Aug 13, 2008 | 09:28 PM
atheros's Avatar
Default Seatbelt warning sound
is there a way to turn off the seatbelt warning sound for the driver side? like pull a fuse or unplug the sensor? i always wear a seatbelt, but it's annoying when i go pickup a friend or girlfriend and wait for them or use atm machine and try to listen to satellite radio in my garage.
thanks.
Old Aug 13, 2008 | 09:55 PM
macscac's Avatar
not sure what model you have.
this worked in my 07 2.ot and also in my 05.5 s4
good luck. most techs will not do this for you
[Select] [17 - Instruments] [Recode - 07] Write down the existing coding for future reference. Enter 5-digit code from below [Do It!] Look at the first two digits in the coding. Add the values for the options together to get the correct coding. 00 - No available equipment +01 - Brakepad wear sensor warning active +02 - Seatbelt warning active +04 - Washer fluid level warning active (may only work with pre-2000 models) +16 - Navigation System (non-USA models) Look at the third digit in the coding (Market version): 0 - "Germany" 24 hour clock 1 - "Rest of World" 24 hour clock 2 - "USA" 12 hour clock 3 - "Canada" 12 hour clock Look at the fourth digit in the coding (Cylinders): 4 - 4-cylinder 6 - 6-cylinder Look at the fifth digit in the coding (Distance impulse multiplier): 0 - TDI Engine (non-USA models) 2 - Non-turbo Gasoline engine 4 - Turbocharged engine So, if you want to have Seatbelt warning and washer fluid warning only in a 1999 Canadian A4 2.8, (add 00+02+04 = 06),3,6,2 = 06362.
Well given the B7 is so much like the B6 underneath other than a revision of the suspension, body panels and some interior stuff, the car's pretty rock solid IMO. Engine also.
As for VAG settings... most of the stuff on the B6 applies for the B7, but here they are for the B7.
Seatbelt chime remove
Address 17 - Instruments --> Recode --> Change xxx5x to xxx0x
xxx?1: Belt warning
0 no belt warning
1 Belt warning Europe NCAP. Optical durable warning, acoustic warning for 91 seconds actively.
2 Belt warning the USA and Canada old. Optical and acoustic warning for 6 seconds
3 Belt warning the USA and Canada NAR again. Optical durable warning, acoustic warning every 30 seconds
4 Belt warning Europe NCAP (incl. front seat passengers). Optical durable warning, acoustic warning for 91 seconds actively
5 Belt warning the USA and Canada old (incl. front seat passengers). Optical and acoustic warning for 6 seconds
6 Belt warning the USA and Canada NAR again (incl. front seat passengers). Optical durable warning, acoustic warning every 30 seconds
Low/high beam with fogs, euro parking lights
Address 09 - Central Electronics
1023 default
1021 enables high beam/fog, Euro parking lights (amber only when blinking)
No seatbelt chime
23261 default
23259 remove seat belt chime
Windows up/down with key FOB
Address 46 - Central Convenience
11820 default
11884 windows up/down with key FOB
Old Aug 13, 2008 | 10:33 PM
atheros's Avatar
macscac what software did you use?
Old Aug 14, 2008 | 02:45 AM
macscac's Avatar
i may or may not work at an audi store
i may or may not have had a tech do it for me
5ViPeRaY5
Oct 3, 2010 08:12 PM
bozack
Audi Q7
Oct 3, 2010 08:10 PM
mani
Dec 21, 2009 08:08 PM
bmickelson
Apr 28, 2008 12:43 PM
dudstone
Mar 3, 2006 08:08 PM
