SQ5 Oil leak
Old Dec 29, 2020 | 03:54 PM
Grantk's Avatar
Default SQ5 Oil leak
I have a 2015 SQ5 with about 110,000 miles on it. Recently I developed an oil leak at the drain plug. According to the private shop mechanic who worked on it, the oil pan is slightly deformed to help the oil drain. Over time, removing and replacing the oil pan has deformed the drain plug even further and they are now recommending the pan be replaced, The replacement pan is about $800. Have other run into this and if so, how have you fixed the problem? Are aftermarket oil pans available?
Thanks in advance
AudimaniaA4
Dec 29, 2012 04:43 PM
Archangel1596
Apr 15, 2009 02:27 PM
nycsweetestt
Jan 1, 2009 10:45 PM
a4turbo1217
Aug 21, 2007 04:07 PM
SouRce4
Mar 6, 2007 02:19 PM
