Squeeking sound
Old Apr 4, 2006 | 07:16 AM
michaelangelo03's Avatar
Default Squeeking sound
I get kind of a wierd squeeking when I turn left. Almost like the sound is coming from inside the dash but it isn't. I listen outside closely while someone turns the wheel and it soounds like its coming from the CV shaft. It doesn;t knock or anything but it bugs the hell out me wen I turn left. When I listen carefully, I hear a very mild squeek even as I'm driving straight. It makes no sense. The squeeking sound isn't even consistent, sometimes it barely makes the sound. Some advice would be great. By the way, I drive a 2000 S4.
Old Apr 4, 2006 | 04:11 PM
Mott Power's Avatar
Default RE: Squeeking sound
Did you check if the CV boot was ripped?
Old Apr 5, 2006 | 02:26 AM
If the CV boot was ripped it should be leaking a nasty grease all over the back of my rim. Nothing but brake dust there mang. That was the first thing I checked.
Old Apr 5, 2006 | 03:12 AM
bajamoon's Avatar
it could be your wheel bearing, when you turn left there is a noise, when you turn right there should be no noise, had the same problem.
Old Apr 5, 2006 | 07:32 PM
Thanks, I'll look into that
mavdog5p
Apr 14, 2008 12:07 AM
pat7755
Nov 22, 2007 01:50 PM
mm107
Oct 5, 2006 11:40 AM
juice88
May 25, 2006 03:26 AM
snobord99
May 12, 2006 08:03 AM
