Test pipe/ down pipes
Old Feb 27, 2009 | 01:04 AM
Quattro_1.8t's Avatar
Default Test pipe/ down pipes
Where is the best place online to find these at a reasonable price? Im buying an 01.5 S4 6 speed and I'm pulling the motor right away to rebuild turbos, change timing belt, water pump, and replace valve cover gaskets. I figured I'd throw on so downpipes and testpipes while the motor is out....
Any help would be great!
Old Feb 27, 2009 | 08:35 AM
SourDieselS4's Avatar
Theres lots of choices
SS Autochrome on ebay sells full turbo backs for dirt cheap, thats certainly the least expensive way. ASP and AWE both have very nice exhaust but its much more expensive than SSAC, they come with Cat's and test pipes. 034 sells downpipes for cheap, you chould have an exhaust shop make you some test pipes pretty darn easily. Theres other companies like labree and fast intentions.
You going with k04's or k03's?
Old Feb 27, 2009 | 02:03 PM
rebuilding the k03s for now. In a year i'll go with gt28s
Old Feb 28, 2009 | 12:12 AM
Deb38's Avatar
Honestly. Just gut your pre-cats. There is a DIY for that. If you want a more aggressive sound, take your downpipes to an exhaust shop and have them cut off your main cats and replace them with a "test pipe"
Old Feb 28, 2009 | 01:59 AM
bigern45's Avatar
gutted my cats and love the extra 10 ponies and less spool time.. hey. since your yanking it out now.. wow... your more than half way there.. id try to locate k04's or something bigger than what you have now... i mean your already putting in all that labor.. geez.. youd think youd go ahead and just at least go k04's....
and cam adjuster seals while your in there!!!!
Old Mar 1, 2009 | 07:15 PM
RoboRabbit's Avatar
if you want something along the lines of asp or awe fast intentions is having a deal right now for $1100 instead of $1600 and with their split design they claim an added 45 hp!
Old Mar 2, 2009 | 03:44 PM
Deb38's Avatar
If I were him, I'd take that 1100 and put it towards K04's. You can see the same gains with piggie pipes.
Old Mar 3, 2009 | 01:53 PM
RoboRabbit's Avatar
i dont want to sound like a dick or anything, but piggies will typically only get about 20-30 bhp increase, and youll also restrict your power output if you put k04's on/ go stage 3 with them because they dont open up as much as aftermarket. piggies in my opinion are more for sound than power. plus he said he wanted gt28s(in which case he would definatly need the bigger pipes)and yall are trying to get him to buy ko4s, haha.
Old Mar 5, 2009 | 04:31 PM
Deb38's Avatar
Show me a dyno or a setup that has shown piggies to be a restriction. The fastest S4's in this country are running piggie pipes. 10secs4 made 470whp with the stock diameter downpipes.
With GT's, of course you are going to need larger downpipes. But K04 turbo's, piggies will be just fine.
mrbillmartin
Apr 1, 2014 09:43 AM
axnjaksn
Apr 4, 2013 09:14 AM
jakgtrey
May 20, 2008 11:02 PM
SAudi
Mar 22, 2007 04:51 PM
Jeff
Feb 15, 2005 09:46 PM
