Turbo lifetime?
Old Sep 27, 2004 | 02:05 AM
etchhead's Avatar
Default Turbo lifetime?
I bought a 01 S4/Tip with 61k on the clock and just chipped CPU/Transmission, swapped diverters, airfilter, oil. The car is incredible! I drive the car fairly conservatively most of the time... what kind of life time can I expect out of the turbos?
Old Sep 27, 2004 | 03:11 AM
David_K's Avatar
Default RE: Turbo lifetime?
If you drive like a business man then the should last you the remianing life of your car. If you drive like a kid they sould last you till about 100k, in between maybe 120-150k
Old Sep 27, 2004 | 06:35 PM
etchhead's Avatar
Thanks for the piece of mind. I've read that the auto tranny can't take the power from the K04's is that just in the first couple of gears? If I do have to upgrade the turbos I still would like to get into the K04s if possible.
Mark
Old Sep 27, 2004 | 08:34 PM
jazz215's Avatar
my tuner said... the limit of the tranny is the ko3's... if i plan to goto k04's, i would need to invest some money into the tranny. (autos are not cheap to rebuild either). I guess ill just keep the ko3's and add dp's and exhaust.
Old Sep 27, 2004 | 09:41 PM
David_K's Avatar
That sounds like a good idea. you can always port and polish the manifolds. this makes the turbos spool about 200% faster.
ThatRetardedKid
Oct 9, 2012 01:55 PM
redline380
Jun 6, 2009 07:47 PM
pangus
B7 Models
26
Sep 6, 2008 09:57 PM
SouRce4
Aug 6, 2006 05:49 AM
jo_no
Mar 8, 2005 03:08 PM
