wont start
Old Oct 30, 2010 | 02:49 AM
vooo5269's Avatar
Default wont start
b5 s4 wont start. i have just replaced the other temp switch both are now green but car still wont start. the coolant level sensor on the bottom of the tank has broken wires. will that cause it not to start? it starts after trying for a little bit
Old Oct 30, 2010 | 02:42 PM
vooo5269's Avatar
someone
Old Nov 3, 2010 | 12:09 AM
FilterS4's Avatar
Is the check eng light on? Have you scanned it for any codes? Could be a number of things. I've had that problem where it would just crank and crank for about 10 seconds and sputter to a start, but it was only after just getting gas. Turned out to be a bad evap purge valve. I've also heard of the engine position sensors going bad that would cause it not to start. Might also be fuel pump / clogged filter.
Old Nov 14, 2010 | 07:25 PM
vooo5269's Avatar
turned out to be the ignition switch
Old Nov 16, 2010 | 12:06 AM
FilterS4's Avatar
Nice. How much did one of those run for?
Dylan Cure
Sep 4, 2012 04:21 AM
zslatcher
Oct 24, 2011 06:15 AM
Billydakid
Oct 29, 2010 02:40 AM
