Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
2001 TT Quattro cv shaft replacement
Old 05-15-2010, 12:57 PM
maxim's Avatar
Default 2001 TT Quattro cv shaft replacement
Does anyone know whether an alignment is required after cv shaft replacement on this car? I was told a slotted front end control bar has to be removed and the car realigned after cv shaft replacement. but, 3 different places told me no, it does not have anything to do with the alignment. Can anyone help?
Old 07-01-2010, 09:03 AM
shockwavecs's Avatar
get a front end alignment ONLY. tell them you will not pay for a rear end alignment because nothing has been changed. they get you hard on that type of stuff. it is usually 40-50 bux instead of double that.
Old 07-02-2010, 10:27 AM
quaTTrophobia's Avatar
The lower control arm is attached to the upright with three screws in slotted holes. Before removing these three bolts, scribe carefully around the washers so as to replace exactly on the scribe mark.
Even tho you do this, the alignment might not have been previously correct. Check the wear patterns on the tires or if you have a digital level use it for camber settings.
Keep in mind you will need to use a new hub bolt in any case.
Old 09-02-2010, 08:25 AM
Autobahn South's Avatar
No you don't generally do an alignment when a cv shaft is replaced but is a good idea to have your alignment checked once a year.
KDaviou
06-23-2013 08:54 PM
fast euro
03-28-2011 01:24 PM
maxim
05-15-2010 01:18 PM
SouthernAudi
03-12-2008 05:29 PM
c2so4
06-08-2005 04:23 PM
Quick Reply: 2001 TT Quattro cv shaft replacement
