Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Offset question
Old Feb 18, 2010 | 11:41 PM
B7_A4's Avatar
Default Offset question
I'm going to be putting 18x8.5 et 35 wheels on my 2008 a4 come spring. the tires wil be 215/40/18. Im going from 17x7.5 et 45 and 235/45/17. I am also going to be installing coilovers as well. With this set up is there any certain spacer size I would need, if at all. I know I need to remember since Im putting the coils on I might not clear the suspension. Im looking either to be flush or not much poke at all. I'm new at this so any info would really be a great help.
Old Mar 21, 2010 | 09:20 PM
ImTheDevil's Avatar
A wheel that wide with a 35 offset is at risk of rubbing the suspension. I have 19x8 wheels and 235-35-19 tires and I'm lowered 2.5". I'm running a 37 offset and on compression of the suspension my outer tires rub the fenders. You're running narrower tires and stretching them, so you may have more wiggle room on tge fender issue but I'm thinking that with the width of those wheels, you're going to have either fender rub or suspension interference depending on whether you run spacers or not (which would probably be only about 5mm spacers).
Syfer23
Mar 3, 2015 12:51 PM
yellow_submarine
Jul 23, 2011 11:55 PM
HartsvilleTT
Sep 29, 2008 03:06 PM
dms
Jun 13, 2006 05:03 PM
headshok2002
Jul 16, 2005 02:29 AM
