VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
buy cheap VAGCOM cable for 2003 A6?
Old Apr 27, 2012 | 02:50 PM
saginus's Avatar
Question buy cheap VAGCOM cable for 2003 A6?
Can anyone send me a ebay product link for a vagcom cable, which is tried and tested on 2003 A6? Cheapest one plz, looking for resetting capability as well.
I am going to use the procedure given at the below link
http://www.club3g.com/forum/electron...nder-10-a.html
let me know if it is correct for A6.
Old Apr 27, 2012 | 10:58 PM
budhani786's Avatar
1. eBay
2.search vag com
3.look for listing with blue cables. There may also be a chart in some that shows compatability. Look in the chart for the c5 a6.
4.start vagging
Old Apr 27, 2012 | 11:03 PM
budhani786's Avatar
That's blue one in the Link is the exact same one I have. If you need it quickly make sure the seller is in USA and not in China
Old Apr 27, 2012 | 11:31 PM
saginus's Avatar
Thanks all...i will order blue cable from ebay
Just to confirm, /budhani786, i will be able to clear/reset the codes,right ? ( and not just check which error it is)
Old Apr 28, 2012 | 08:04 AM
budhani786's Avatar
You will not only be able to do that but you will able to do some logging. Not to mention program your keys to roll the windows up if you hold the lock button. And holding the unlock remote button will roll the windows down. I have been able to clear codes on my 01 2.8 and my friends 02 2.7 so the 03 3.0 would also work.
Old Apr 28, 2012 | 01:52 PM
saginus's Avatar
Old May 3, 2012 | 12:02 AM
saginus's Avatar
i finally got the cable..
New KKL VAG-COM Diagnostic USB Cable interface OBD2 For VW AUDI 409.1 Version | eBay
But I am not able to connect... it keeps trying to connect.. I did check COM4, and it passed... plz help
Old May 3, 2012 | 12:29 AM
saginus's Avatar
never mind... figured it out..atleast i am not able to connect it to the car...
mad_bison
Apr 29, 2012 03:59 PM
pbrules10
Feb 12, 2012 12:21 PM
foxracing4500
Apr 23, 2011 01:10 PM
freestyleski
Oct 17, 2007 10:22 PM
DVA
Feb 10, 2006 09:03 PM
