VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Enable Comfort Turn Signals On A Audi A4 B8 3.2 Quattro
Old May 18, 2018 | 08:06 AM
thavinci's Avatar
Default Enable Comfort Turn Signals On A Audi A4 B8 3.2 Quattro
Hi, being a noob at vcds I have managed somehow to disable the Comfort Turn signals on my vehicle.
I have added quite a few of the mods listed out there and in the process somewhere along the line managed to disable the function where you simply tap the indicator to indicate lane change. (To which is flashes a few times and auto disables)
Yes I know i should have tracked changes. (which i now do) But i have no idea how to enable this again.
Anyone out there know the coding to enable this awesome feature again?
Old May 18, 2018 | 08:08 AM
thavinci's Avatar
Default VAG Scan
Wednesday,16,May,2018,18:18:54:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
Ross-Tech: Home
VIN: WAUZZZ8K3AA108936 License Plate:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72
77
VIN: WAUZZZ8K3AA108936 Mileage: 150040km-93230miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CALA) Labels: 06E-907-559-CAL.clb
Part No SW: 8K0 907 559 HW: 8F0 907 559 B
Component: 3.2 SIMOS8.2 H06 0001
Revision: --------
Coding: 0104000C190F0121
Shop #: WSC 06325 123 12345
ASAM Dataset: EV_ECM32FIS8K0907559 A01003
ROD: N/A
VCID: 76E43D9AC95C7DF1C3-8022
No ASAM data for: "EV_ECM32FIS8K0907559" (AU48)
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 G HW: 0B6 927 156
Component: 0B6 32 FSIRdW H05 0006
Revision: --H05---
Coding: 001011
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 3A7CE9AABDC4D991E7-806E
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AL HW: 8K0 907 379 AL
Component: ESP8 quattro H04 0080
Revision: -------- Serial number: --------------
Coding: 0F0500
VCID: 0302544E828E5859F4-8056
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0327
Revision: 00002001
Coding: 011100
VCID: 010E5E4698924A49E6-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000073906014
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000100227010
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01121220091083
Coding: 46040000
VCID: 76E43D9AC15C7DF1C3-8022
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000537275
Coding: 2600D8914134AF010001000000001D0D4F1D43080001014100 0000
VCID: 3A7CE9AAB5C4D991E7-806E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 081008 H05 0070
Serial number: SWF08100080199
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10714775
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000712090246
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 23
Mileage: 149183 km
Time Indication: 0
Date: 2018.05.12
Time: 12:31:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 J HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0050
Revision: 11001001 Serial number: 39840934907703
Coding: 100103
VCID: 40889B42D3188341A9-8014
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD08BS28
Coding: 30363435363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWADUI010 003010
ROD: N/A
VCID: 418E9E46D0128A49A6-8014
Subsystem 1 - Serial number: 6334MSME4F054D66Q
Subsystem 2 - Serial number: 6344MSME4D430B01A
Subsystem 3 - Serial number: 6352QSME3048320A7
Subsystem 4 - Serial number: 6362QSME3E482228L
Subsystem 5 - Serial number: 63732SME09471C380
Subsystem 6 - Serial number: 63832SME09471A06.
No ASAM data for: "EV_AirbaECUVWADUI010" (AU48)
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304ILC0009B
Coding: 000036
VCID: 3D76E2B6A4EAEEA9C2-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 B HW: 8K0 920 930 B
Component: KOMBIINSTR. H20 0255
Revision: 00100000 Serial number: CIV322CD9
Coding: 2F1F09000200000C010000
VCID: 2C50DFF24F90772165-8078
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G09C058437
Coding: 00C303
VCID: 50A8AB02037873C139-8004
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1909FAD9021209
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 7
Mileage: 148142 km
Time Indication: 0
Date: 2018.04.26
Time: 15:59:52
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009804504
Coding: 011C02204001410001
VCID: 45868A56CC3AA6699A-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0124991485
Coding: 011A0622003904040130013280000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
Address 47: Sound System (J525) Labels: 8T0-035-223-BOC.clb
Part No SW: 8T0 035 223 AR HW: 8T0 035 223 AJ
Component: DSP Prem H19 0320
Revision: 00019001 Serial number: 34835000372302
Coding: 0203010302
Shop #: WSC 01621 996 999999
VCID: 7EF425BAE96C35B19B-802A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009771592
VCID: 44809752C7009F618D-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000396369
Shop #: WSC 00000 000 00000
VCID: 3460C79297A02FE13D-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 77FA309E065604F9D8-8022
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
Component: Concert3 H04 0310
Revision: 00000007 Serial number: AUZ5Z6I1324058
Coding: 0503008201018D00835B070002
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102519821
Coding: 010C02204001210001
VCID: 428C914ADD149151BF-8016
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102519824
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
Component: FSE_256x BT H39 0600
Revision: 00000000 Serial number: 00000005145083
Coding: 0010390
VCID: 3B72ECAE7AFEE099FC-806E
End-------------------------(Elapsed Time: 03:24)--------------------------
Old Jan 27, 2022 | 02:33 PM
Cobailer's Avatar
I don't think even a 1/4 of the people from this forum can understand that code. And even if they do, I'm sure no one can really help you. With such a problem you should consider going to a repair shop. There are the right people to help you with the issue. When my car started showing lousy coding, I immediately took it to a repair centre. They were using https://autoleap.com's software, so it was easy to find out where the problem was and how to fix it. I hear that nowadays most shops use it. Perhaps you can call some repair shops and ask if they can help you out.
bballfreak
Mar 19, 2022 11:16 AM
thavinci
Sep 21, 2019 04:49 AM
Ahmcam
Jun 14, 2015 12:27 PM
eazy211187
Dec 30, 2012 04:53 PM
Tom$lick
May 24, 2009 08:17 PM
