VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
misfire CELs w/ vagcom readings / logs
Old Mar 30, 2008 | 01:06 PM
EOD5's Avatar
Default misfire CELs w/ vagcom readings / logs
hey guys - had this posted in computer / fuel but no one really looks there so i figure ill post it here too:
I just bought this car a few weeks ago. the previous owner put in Piper Cams 272* - which i have been told should not throw codes
all mods are in my sig
right now it is pulling p0300 - combustion misfire.... p0302 misfire cyl2 ... m0304 misfire cyl 4
when i first got it (before replacing anything) it was pulling p0300 0301 0302 0303 and 0304
ive replaced all spark plugs with BRK7E gapped to .028....replaced all 4 coil packs with new ones....
im looking for other suggestions... i need to get this gone by 5/18 so i can register it, i have temp tags now
REPLACED SO FAR:
- all 4 coil packs
- ICM
- spark plugs (bkr7e @ 0.028 gap)
- ECT or CTS whatever you want to call it... COOLANT TEMP
- Cleaned MAF
Old Apr 5, 2008 | 10:13 PM
EOD5's Avatar
Default RE: misfire CELs
bump....replaced the ICM now, and still no fix
Old Apr 5, 2008 | 10:57 PM
hiwords's Avatar
replace the ECT
Old Apr 5, 2008 | 11:00 PM
EOD5's Avatar
engine coolant temp sensor?
.... or did you mean somethign else? im confused
Old Apr 5, 2008 | 11:03 PM
EOD5's Avatar
oh i wanted to note also...i dont feel hesitation or stuttering...car runs great and runs strong...just CEL is thrown
Old Apr 5, 2008 | 11:04 PM
hiwords's Avatar
have you cleared it? it might just be a stored code
Old Apr 5, 2008 | 11:05 PM
EOD5's Avatar
cleared it MANY times....it keeps coming back....i dont know what else to check or change.....
did you mean ECT as coolant temp sensor? or something else?
Old Apr 5, 2008 | 11:06 PM
hiwords's Avatar
ya temp sensor, the techs say it can do funny things to our cars sometimes. did you double check the gaps? idk what else to tell you to change lol.
Old Apr 5, 2008 | 11:14 PM
EOD5's Avatar
doubled checked em...im outta luck...ill try the ECT..have you heard of it causing misfires before?
Old Apr 5, 2008 | 11:16 PM
hiwords's Avatar
yes a couple of times. also do some seafoam treatment.
